15 years agoI'm not an expert but wonder if you are able to simulate your digital filter behaviour.
If running a simulation with a constant input, you see it lowered, then it depends on the FIR filter. Further the simulation can tell you which is the correct format of the output (MSB representation etc.) Otherwise, can it be the DAC? hope this helps.
