SBioo's avatar
SBioo
7 years ago
Unexpected OpenCL compilation results
I have a simple kernel code, which is supposed to mimic the matrix multiplication in a single-thread mode in the OpenCL. Below you can see the code:
// (c) January 9, 2019 Saman Biookaghazadeh @ Arizona State University
#ifdef INT_PRECISION
#define DTYPE int
#elif SINGLE_PRECISION
#define DTYPE float
#elif DOUBLE_PRECISION
#pragma OPENCL EXTENSION cl_khr_fp64: enable
#define DTYPE double
#endif
#include "../TSVC/funcs.h"
__kernel void mm (__global const DTYPE* restrict A,
                  __global const DTYPE* restrict B,
                  __global DTYPE* restrict C,
                  const DTYPE alpha,
                  const DTYPE beta,
                  const int lllX,
                  const int lllY)
#ifdef GPU
  const int row = get_local_id(0);
  const int col = get_local_id(1);
	const int globalRow = 32 * get_group_id(0) + row;
  const int gloBalCol = 32 * get_group_id(1) + col;
  // Local memory to fit a tile of 32*32 elements of A and B
  __local float Asub[32][32];
  __local float Bsub[32][32];
  // Initialize the accumulation register
  float acc = 0.0f;
  // Loop over all tiles
  const int numTiles = lllY/32;
	for (int t = 0; t < numTiles; t++) {
    // Load one tile of A and B into local memory
    const int tiledRow = 32*t + row;
    const int tiledCol = 32*t + col;
    Asub[col][row] = A[tiledCol*M + globalRow];
    Bsub[col][row] = B[globalCol*K + tiledRow];
    // Synchronize to make sure the tile loaded
    barrier (CLK_LOCAL_MEM_FENCE);
    // Perform the computation for a single tile
    for (int k = 0; k < 32; k++) {
#if INTENSITY1
			megaBfunction1(acc, Asub[k][row], Bsub[col][k]);
#elif INTENSITY2
			megaBfunction2(acc, Asub[k][row], Bsub[col][k]);
#elif INTENSITY3
			megaBfunction3(acc, Asub[k][row], Bsub[col][k]);
#elif INTENSITY4
			megaBfunction4(acc, Asub[k][row], Bsub[col][k]);
#elif INTENSITY5
			megaBfunction5(acc, Asub[k][row], Bsub[col][k]);
#endif
  C[globalCol*M + globalRow] = acc;
#endif
#ifdef FPGA_SINGLE
	for (int i = 0; i < lllX; i++) {
		for (int j = 0; j < lllX; j++) {
      DTYPE temp = 0.0f;
      #pragma ivdep
      for (int z = 0; z < lllY/BLOCK_SIZE; z++) {
        DTYPE A_local[BLOCK_SIZE];
        DTYPE B_local[BLOCK_SIZE];
        DTYPE local_temp = 0.0f;
        // Coalescing memory read from the memory section "A"
        #pragma unroll
        for (int k = 0; k < BLOCK_SIZE; k++) {
          A_local[k] = A[i*lllY+z*BLOCK_SIZE+k];
        #pragma unroll
          B_local[k] = B[j*lllY+z*BLOCK_SIZE+k];
        #pragma unroll
#if INTENSITY1
					megaCfunction(local_temp, A_local[k], B_local[k], alpha);
#elif INTENSITY2
					megaCfunction2(local_temp, A_local[k], B_local[k], alpha);
#elif INTENSITY3
					megaCfunction3(local_temp, A_local[k], B_local[k], alpha);
#elif INTENSITY4
					megaCfunction4(local_temp, A_local[k], B_local[k], alpha);
#elif INTENSITY5
					megaCfunction5(local_temp, A_local[k], B_local[k], alpha);
#endif
        temp += local_temp;
      C[i*BLOCK_SIZE+j] = temp;
#endif
When I compile the code and obtain the html reports, I can see that the LD (load) nodes bit-width is being set to 32, while it should actually be 32*BLOCK_SIZE, since the for loop with the BLOCK_SIZE iteration length is fully unrolled. I cannot fully understand why such a thing is happening, or what kind of optimization the OpenCL compiler is applying on my kernel code.
I do appreciate if anyone can help me with this issue.
  • HRZ's avatar
    HRZ
    I cannot compile your code to check the report without the "funcs.h" header. I would assume you are talking about lines 92 and 97. I cannot see any reason why those accesses should not be coalesced. Is the compiler inferring one 32-bit access for each buffer or 16 per buffer? If it is just one, then parts of your circuit are being optimized out for some reason. If it is 16, the compiler is refusing to coalesce the accesses for some reason. The reason could, for example, be the configuration of the A_local and B_local buffers which will very likely be implemented as multi-ported RAMs. If the compiler decides to use a 32-bit width for those buffers based on the access pattern in the "megaCfunction"s, then it would not coalesce the accesses to either the global buffers or the local buffers in lines 92 and 97. You should probably check the width, depth and number of accesses to the local buffers in the report.
  • SBioo's avatar
    SBioo
    Sorry for not attaching the funcs.h. Here I have attached the file.
  • HRZ's avatar
    HRZ
    I ran a test with random variables using the following command since I have no idea what I should set the compile-time variables to:
    aoc -c -v --report test.cl -DSINGLE_PRECISION -DFPGA_SINGLE -DBLOCK_SIZE=16 -DINTENSITY5 -DNUMFMAS=5
    Indeed it seems much of your design is being optimized out by the compiler; hence the narrow read/write ports. Does your code produce correct results in the emulator?
  • SBioo's avatar
    SBioo
    Thanks much for the reply,
    As you mentioned, the code was hugely being optimized out, due to some issues in my implementation of mega functions. I have re-factored the definitions and they are working fine right now.
    Thanks much again for the help.
