SBioo
7 years agoUnexpected OpenCL compilation results
Hi, I have a simple kernel code, which is supposed to mimic the matrix multiplication in a single-thread mode in the OpenCL. Below you can see the code: //
// (c) January 9, 2019 Saman Biookaghaza...
HRZ
7 years agoI ran a test with random variables using the following command since I have no idea what I should set the compile-time variables to:
aoc -c -v --report test.cl -DSINGLE_PRECISION -DFPGA_SINGLE -DBLOCK_SIZE=16 -DINTENSITY5 -DNUMFMAS=5
Indeed it seems much of your design is being optimized out by the compiler; hence the narrow read/write ports. Does your code produce correct results in the emulator?
