Understanding timing constraints in timing analyzer
Thank you sstrell for answering.
Hi OP,
I believe sstrell has answered your inquires, do you able to close timing with your project?
Richard Tan
- FvM1 year ago
I agree that the design should be fully constrained so that timing analyzer doesn't report unconstrained pathes any more.
It's however rather unlikely that reported timing violations are caused by unconstrained IO. Consider a design with only asynchronous IO, it doesn't need specific IO constraints other than setting all IO to false_path. FPGA core logic will still violate timing if combinational delay between registers is too large. It can be only solved by restructuring logic, e.g. adding pipeline registers. Even in a partly unconstrained design, timing analyzer can show you why certain pathes fail timing closure.- sstrell1 year ago
Agreed.
Another solution may be to just create virtual pin assignments for all I/O. Then the design is basically self contained in the device.
