makotolagano
4 years agoUnconstrained base clock in state machine design
I am trying to make a state machine for controlling LEDs as tail lights are controlled on Ford Thunderbird. The board I'm using is DE0 Nano with Cyclone IV.
The state machine part is working fine, ...
- 4 years ago
You created clk_50 as a virtual clock instead of a base clock because you didn’t set a target (typically with get_ports). Then you have to create a generated clock with the source as clk_50 and the target as the output of your clock divider and accurately describe the relationship between the two. You also should have input and output delay constraints for the I/O.
Farabi_Altera
4 years agoHello,
