FabianL
1 year agoUnable to use Avalon-MM master verification BFM in Questa sim
Hello, I have a bug similar to the one reported here : https://community.intel.com/t5/Intel-Quartus-Prime-Software/Avalon-Verification-IP-example-avlmm-1x1-vhdl-not-working-in/m-p/1516388 or here ...
KennyT_altera
1 year agoI am getting a different error:
** Warning: (vopt-10908) Some optimizations are turned off because the +acc switch is in effect.
# ** Error (suppressible): test_program.sv(229): (vopt-7063) Failed to find 'set_command_address' in hierarchical name '$root.tb.dut.master_0.set_command_address'.
# Region: tb.tp
# ** Error (suppressible): test_program.sv(229): (vopt-7063) Failed to find 'set_command_burst_count' in hierarchical name '$root.tb.dut.master_0.set_command_burst_count'.
# Region: tb.tp
# ** Error (suppressible): test_program.sv(229): (vopt-7063) Failed to find 'set_command_burst_size' in hierarchical name '$root.tb.dut.master_0.set_command_burst_size'.
Will get back to you if i manage to duplicate your error.
