Unable to simulate designs comprising FFT (ModelSim Intel FPGA Starter Edition 10.5b and 10.6d)
To get this design to simulate correctly , you need to compile the following files in order.
1. From the /simulation folder - the top-level fft design .v file
2. From the /simulation/submodules folder –
a. All of the _pkg.vhd files first
b. Then the _roundsat.vhd file
c. Followed by the rest of the .vhd files
3. Next, compile the files in the /simulation/submodules/mentor folder-
a. The Verilog files (there are only 2 of them)
b. All of the pkg files first
c. Then the apn_* VHDL files
d. Followed by the asj_* VHDL files -> except the asj_fft_sglstream. This one needs to be compiled last.
e. Next compile the rest of the files auk_* VHDL
f. Lastly compile the asj_fft_sglstream.vhd file.
4. All of the files should be compiled successfully and you should be able to see them in the work folder.
Now simulate the top-level module of the design or testbench. It will load successfully
