Vandana_GS
2 years agoUnable to run Embedded Command Shell v19.3
Hi, I have installed Quartus Prime software v24.1. I need to run embedded command shell in the Intel SoC Embedded Design Suite(EDS) Professional Edition version 19.3. After installation of the both ...
- 1 year ago
The last SoCEDS embedded command shell is only available with the quartus v2020.1.
https://www.rocketboards.org/foswiki/Documentation/SoCEDS
SoCEDS is EoL-ed from Intel-Altera in 2020. So there will be very less or no support from the us. Please refer the updated HWLIB Github-https://www.rocketboards.org/foswiki/Documentation/HWLib
If you are using the Quartus v24.1, then you need to have separate ARM DS tool and it doesn't need soceds embedded command shell to run.
Tiwari
Vandana_GS
1 year agoHi,
Thank you for the reply. The above reply solved our issue.
