Unable to run Embedded Command Shell v19.3
- 1 year ago
The last SoCEDS embedded command shell is only available with the quartus v2020.1.
https://www.rocketboards.org/foswiki/Documentation/SoCEDS
SoCEDS is EoL-ed from Intel-Altera in 2020. So there will be very less or no support from the us. Please refer the updated HWLIB Github-https://www.rocketboards.org/foswiki/Documentation/HWLib
If you are using the Quartus v24.1, then you need to have separate ARM DS tool and it doesn't need soceds embedded command shell to run.
Tiwari
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
