Loopback
2 years agoUnable to generate simulation files for avalon memory mapped read, write and slave IP
I have an existing QPP project, where I want to generate simulation files, so that I can better understand the inter module communication and data flow. I'm getting following errors in the generate d...
sstrell
2 years agoThen that means whatever these components are, they do not have simulation models available for them.
If these are your own custom components, they need to have Verilog simulation model files specified in the Component Editor when the component is created for this to work. You can specify the same design files should be used for both synthesis and simulation, but if no simulation model files are specified, you'll get these errors.
