ove's avatar
ove
1 month ago
Unable to download Quartus
Trying to download Quartus 25.3.1 Pro, but installed throws this every time
Tried for several days now with the same result. Also tried another installed ( 25.3) and the Lite (25.1) installed with the same result.
My internet connection is working fine.
  • Recently, there is an issue with the installer certification and this will be fixed in the next Quartus installer release.
    I am not sure if this might be the cause as the error message should stated :
    Test download failed with certificate error: SSL certificate problem: unable to get local issuer certificate (curlcode 60)
    However, you will need to apply the workaround below; otherwise, the installer will display the error shown above.Please let me know how it goes after you have applied the workaround.
    Workaround:
    Kindly download the attached cacert.pem (unzip it first) to your machine, and from the installer settings, please specify to the new cacert.pem and test the connection.
    You should be able to download it.
    Richard Tan
      • RichardT_altera's avatar
        RichardT_altera
        Which Quartus installer are you using?
        What error message are you encountering?
        Please provide the steps you performed to trigger the error, as well as any debugging or troubleshooting steps you have already taken.
        Richard Tan
