Unable to download Quartus
Recently, there is an issue with the installer certification and this will be fixed in the next Quartus installer release.
I am not sure if this might be the cause as the error message should stated :
Test download failed with certificate error: SSL certificate problem: unable to get local issuer certificate (curlcode 60)
However, you will need to apply the workaround below; otherwise, the installer will display the error shown above.Please let me know how it goes after you have applied the workaround.
Workaround:
Kindly download the attached cacert.pem (unzip it first) to your machine, and from the installer settings, please specify to the new cacert.pem and test the connection.
You should be able to download it.
Richard Tan
Still not working!
- RichardT_altera8 months ago
Which Quartus installer are you using?
What error message are you encountering?
Please provide the steps you performed to trigger the error, as well as any debugging or troubleshooting steps you have already taken.
Richard Tan- Sheikh_Sadi_RMIT8 months ago
I tried to install Quartus 25.1 by Quartus Prime Lite Edition Installer (SFX) and got an error message. I tried out all the step available on internet to fix this. From command prompt to updating & reinstalling the drivers. Though my Wi-Fi is working perfectly, I'm getting the same connection error message. I also tried your way to download it. Still no progress.
From one of your screenshot, it stated that the CA certificate file appears to be invalid. You might need to put the full path name, e.g. C:\Users\Downloads\cacert.pem. Then click Apply and see if it works.
Alternatively,
Open a command prompt or terminal and run the installer with the --cacert option, pointing to the new certificate file
Windows:qinst_<version>.exe -sp"--cacert <full path to cacert.pem>"
Richard Tan
