12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years agoReally I got 5 warnings about time restrictions during the compilation.
These warnings say that I need to specify some restrictions in a SDC file before compiling. I am reading the following documentation from Altera: White Paper - Understanding Metastability in FPGAs http://www.altera.com/literature/wp/wp-01082-quartus-ii-metastability.pdf 14. Managing Metastability with the Quartus II Software http://www.altera.com/literature/hb/qts/qts_qii51018.pdf 7. The Quartus II TimeQuest Timing Analyzer Is that the way (TimeQuest Timing Analyzer) to correct the metastability using quartus II? I attached a TimeQuest screenshot where it tells me that I need specify a SDC file. The first and the second process in the TimeQuest are checked as we can see in the screenshot. Thanks.
