12 years agoUART and MODELSIM ALTERA (code attached)
Hi dears. I am trying to use a (slightly) modified version of the UART explained in a tutorial I've found, after reading some theory about. There is one UART entity which has two c...
12 years agoIn resume, why the en_mod is not changing again to '0' in uart_rx when the start bit is detected ?
case state_reg is when idle => if (rx = '0') then state_next <= start; en_mod_reset <= '0'; -- mod 27 set, counting. s_next <= (others => '0'); end if; Thanks.
