11 years agoTTTL finder / output and input
Hello,I want to create a circuit which has two inputs a clock and an enable and three outputs. What I want this circuit to do is that it has a variable (cont) that goes from "00" to "11" and two of the outputs (sal_1 and sal_2) take the values of cont(0) and cont(1) and go to the inputs of a ttl ic (AND , OR, XOR) and then the output of the ttl ic goes back to the circuit and is saved (results) after that, the vector that is created from the differents results of the ttl ic ouputs is compared with vectors already predefined and find the one that matches it and returns the value.I have a hard time with the output and then input times, it seems that there is a special way to do this.Here is my code:
library IEEE;use IEEE.std_logic_1164.all;use IEEE.numeric_std.all;use IEEE.std_logic_unsigned.all;use IEEE.std_logic_arith.all;entity ttl_finder is port( clk, ena, sal_ttl : in std_logic; sal_1, sal_2 : out std_logic; sal_f : out std_logic_vector(3 downto 0));end entity;architecture ttl_tester of ttl_finder issignal cont : std_logic_vector(1 downto 0) := "00";signal results : std_logic_vector(3 downto 0) := "0000";beginprocess(clk, ena)variable c : std_logic;variable d : std_logic;variable e : std_logic;beginif ena = '1' then if cont < "11" then sal_1 <= cont(0); sal_2 <= cont(1); if rising_edge(clk) then results(conv_integer(cont)) <= sal_ttl; end if; cont <= cont + 1; else sal_1 <= cont(0); sal_2 <= cont(1); if rising_edge(clk) then results(conv_integer(cont)) <= sal_ttl; end if; cont <= "00"; end if;end if;end process;sal_f <= results;end ttl_tester;
