Trying to understand on-chip memory
- 1 year ago
You should declare the output q as a wire, because the ROM module already registers the output internally.
You do not need to add your own always @(posedge clk) just to capture q, unless you want to add pipeline stages or synchronize it further.
The altsyncram component is configured with:
altsyncram_component.outdata_reg_a = "CLOCK0"
This means the output is registered on the rising edge of clock0 inside the IP — so the ROM fetches data synchronously, with output changes one clock cycle after the address is applied.
So even though q is declared as a wire, it is driven by a register inside the ROM IP. That’s why your code can simply declare:
wire [7:0] q;
rom rom_inst (
.address (address),
.clock (clock),
.q (q)
);And it should works exactly as a synchronous ROM should.
So yes — you're absolutely right: you cannot use q on the same clock edge that you apply the address. You need to wait one clock cycle.
Richard Tan
Thank you for the confirmation.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
