Trying to understand on-chip memory
- 1 year ago
You should declare the output q as a wire, because the ROM module already registers the output internally.
You do not need to add your own always @(posedge clk) just to capture q, unless you want to add pipeline stages or synchronize it further.
The altsyncram component is configured with:
altsyncram_component.outdata_reg_a = "CLOCK0"
This means the output is registered on the rising edge of clock0 inside the IP — so the ROM fetches data synchronously, with output changes one clock cycle after the address is applied.
So even though q is declared as a wire, it is driven by a register inside the ROM IP. That’s why your code can simply declare:
wire [7:0] q;
rom rom_inst (
.address (address),
.clock (clock),
.q (q)
);And it should works exactly as a synchronous ROM should.
So yes — you're absolutely right: you cannot use q on the same clock edge that you apply the address. You need to wait one clock cycle.
Richard Tan
small correction to above description.
Internal block RAM doesn't necessarily register RAM/ROM output. It always registers memory address, write data and related control signals, output register is optional and controlled by parameter outdata_reg_a/b which can be UNREGISTERED, CLOCK0 or CLOCK1.
Respectively RAM/ROM output has either 1 or 2 clock cycles latency.
Using "wire" to connect memory output port q should work for both configurations.
Frank
