11 years agoTrouble with programming device under Linux
Hello, this is my first post here. I'm a student from germany, and had a basic course in FPGA programming with Altera Quartus at university for the last half year. We used some university com...
10 years agoThe following solution works on Ubuntu, and may also work on other Linux distros.
Log in as root (sudo -s), and create a new file named /etc/udev/rules.d/90-usb-blaster.rules, with the following content:SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="0666" Once the file is saved, plug the USB Blaster back into a USB port and select it within Quartus Programmer. Explanation: The MODE="0666" setting gives all users read and write permissions to USB Blasters plugged into the computer, and allows the Quartus Programmer to function properly. By default, all users are typically given only read permissions. -rtxTowerLy
6 years agoHi,
I faced with the same problem on windows 7, stratix 10 Gx devkit and Quartus Pro v20.2. Do you have any idea about this?
Samet
