Trouble populating memory from text file
Hello everyone, I need help populating my memory from a text file. Here is my RAM vhdl code:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE STD.TEXTIO.ALL;
-- Add a generic parameter
ENTITY rem_ram IS PORT (
address : IN std_logic_vector(7 DOWNTO 0);
read_data : OUT std_logic_vector(31 DOWNTO 0)
END ENTITY rem_ram;
ARCHITECTURE rtl OF rem_ram IS
TYPE ram_type IS ARRAY(0 TO (2**address'LENGTH)-1) OF std_logic_vector(read_data'RANGE);
FUNCTION init_rom RETURN ram_type IS
VARIABLE r : ram_type;
BEGIN
FOR i IN r'RANGE LOOP
r(i) := (OTHERS => '0');
END LOOP;
RETURN r;
END FUNCTION;
-- FILL MEMORY FROM TEXT FILE
FUNCTION fill_memory RETURN ram_type IS
VARIABLE mem : ram_type;
TYPE HexTable IS ARRAY (CHARACTER RANGE <>) OF INTEGER;
CONSTANT lookup : HexTable('0' TO 'F'):=
(0, 1, 2, 3, 4, 5, 6, 7, 8, 9, -1, -1, -1,
-1, -1, -1, -1, 10, 11, 12, 13, 14, 15);
FILE infile: text OPEN read_mode IS "mem_ram.txt";
VARIABLE buff: LINE;
VARIABLE addr_s: STRING(2 DOWNTO 1);
VARIABLE data_s : STRING(8 DOWNTO 1);
VARIABLE addr1, byte_cnt: INTEGER;
VARIABLE data: INTEGER RANGE 4294967295 DOWNTO 0;
BEGIN
WHILE (not endfile(infile)) LOOP
readline(infile, buff);
read(buff, addr_s);
read(buff, byte_cnt);
addr1 := lookup(addr_s(2))*16 + lookup(addr_s(1));
readline (infile, buff);
FOR i IN 1 TO byte_cnt LOOP
read(buff, data_s);
data := lookup(data_s(8))*268435456 + lookup(data_s(7))*16777216 + lookup(data_s(6))*1048576 +
lookup(data_s(5))*65536 + lookup(data_s(4))*4096 + lookup(data_s(3))*256 +
lookup(data_s(2))*16 + lookup(data_s(1));
mem(addr1) := CONV_STD_LOGIC_VECTOR(data, 32);
addr1 := addr1 + 1;
END LOOP;
END LOOP;
RETURN mem;
END FUNCTION;
SIGNAL ram : ram_type := fill_memory;
BEGIN
read_data <= ram(CONV_INTEGER(UNSIGNED(address)));
END ARCHITECTURE rtl;
and here is the text file:
00
8C020000
04
8C030001
08
00430820
0C
AC010003
10
1022FFFF
14
1021FFFA
I suspect that maybe there's an illegal (outside of the hex range) character in the .txt file but I don't see any. Maybe I need to save the text file in a different encoding format? Like ASCII or UTF-8? Thanks everyone!10 Replies
Forgot to specify the exact error I am getting
Error (10385): VHDL error at rem_ram.vhd(46): index value nul is outside the range ('0' to 'F') of object "lookup" Error (10658): VHDL Operator error at rem_ram.vhd(46): failed to evaluate call to operator ""*"" Error (10658): VHDL Operator error at rem_ram.vhd(46): failed to evaluate call to operator ""+"" Error (12153): Can't elaborate top-level user hierarchy Error: Quartus Prime Analysis & Synthesis was unsuccessful. 4 errors, 1 warning Error: Peak virtual memory: 696 megabytes Error: Processing ended: Fri Mar 09 15:50:18 2018 Error: Elapsed time: 00:00:15 Error: Total CPU time (on all processors): 00:00:34 Error (293001): Quartus Prime Full Compilation was unsuccessful. 6 errors, 1 warning - Altera_Forum
Is this for simulation? Altera doesn't support initialisation of ram from text file during synthesis.
This is for compilation. Well, that is too bad then.
Even if it was possible, there are other issues with the code. For a start, this seems like a terribly complicated way to initialise the ram. Whats wrong with just reading the values straight to a std_logic_vector? non-standard std_logic_textio package has the hread function to do just that. (in VHDL 2008, this is included in std_logic_1164 package).
Then there is the problem that most implementations limit integer to 2**31-1. So integer cannot be given a value of 2**32. Also, Strings are usually declared (1 to N) by convention, rather than (N downto 1). - Altera_Forum
Instead of doing it in code, you could use a .hex or .mif file to initialize the RAM.
So instead of using .txt file, i just need to change it to .mif?
No, you have to use an attribute to populate the ram with a .mif/.hex:
http://quartushelp.altera.com/15.0/mergedprojects/hdl/vhdl/vhdl_file_dir_ram_init.htm Be aware though, that this will NOT initialise the ram during simulation. You will need to read in the text file and parse it manually. If you use a ram from the megafunctions library, you can specify the .mif as a generic and this block will parse the file for you, populating the contents in both simulation and synthesis. - Altera_Forum
the link is broken?
link works for me from 2 different places - on google chrome?
Firefox. But I disabled HTTPS-Everywhere and it works fine now.
