8 years agoTrouble populating memory from text file
Hello everyone, I need help populating my memory from a text file. Here is my RAM vhdl code: LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE STD.TEXTIO.ALL;
-- Ad...
8 years agoForgot to specify the exact error I am getting
Error (10385): VHDL error at rem_ram.vhd(46): index value nul is outside the range ('0' to 'F') of object "lookup"
Error (10658): VHDL Operator error at rem_ram.vhd(46): failed to evaluate call to operator ""*""
Error (10658): VHDL Operator error at rem_ram.vhd(46): failed to evaluate call to operator ""+""
Error (12153): Can't elaborate top-level user hierarchy
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 4 errors, 1 warning
Error: Peak virtual memory: 696 megabytes
Error: Processing ended: Fri Mar 09 15:50:18 2018
Error: Elapsed time: 00:00:15
Error: Total CPU time (on all processors): 00:00:34
Error (293001): Quartus Prime Full Compilation was unsuccessful. 6 errors, 1 warning
