BobA
1 year agoTrouble licensing Questa Starter Edition
Hi, I have Quartus Prime Lite 24.1std.0. I select Tools->Run Simulation Tool->RTL Simulation and get a Fatal License Error, Unable to checkout a license. I've gotten a license file from Intel and s...
paveetirrasrie_Altera
1 year agoHello Bob,
You may delete the MGLS_LICENSE_FILE environment variable or update its value to point to your correct license path.
It looks like Questa is currently using MGLS_LICENSE_FILE, but the path specified is invalid or does not exist.
This is likely the root cause of the issue.
The MGLS_LICENSE_FILE takes precedence over LM_LICENSE_FILE settings. Kindly let me know if this helps on resolving the issue.
Pavee
- BobA1 year ago
I removed the MGLS_LICENSE_FILE environment variable, but I'm still getting the "Unable to checkout a license" error.
