9 years agoTrouble hardcoding an initial value of flip-flop on power up.
Hi All, I'm using a Max 10 FPGA. I'm having trouble instantiating a d flip flop initially set to '1'. From the altera.altera_primitives_components.all I am instantiating the following...
9 years agoWhy are you using the primitives? why not infer the register, because then you can apply the initial value yourself:
signal q : std_logic := '1'; -- initial value
process(clk)
begin
if clrn = '0' then
q <= '0';
elsif prn = '0' then
q <= '1'
elsif rising_edge(clk) then
q <= d;
end if;
end process;
If a register has async clear, it often uses this as the power on value if none is specified. If you have to use the primitives, I think you can assign the power on value in the project assignments. You will need to compile the project to get the register path from the node finder.
