12 years agotree structure
hii
pls give an idea to implement a verilog code to construct a tree structure.Also an array reusing idea.because we need to reduce the array size each time.hii
pls give an idea to implement a verilog code to construct a tree structure.Also an array reusing idea.because we need to reduce the array size each time.This is far too few information.
What exactly do you need? Do you want to create a Top-Entity which holds one or more Objects of your Verilog-Code? I think for beginners it would be a good start to create a Symbol-File of your code and place it in a Schematic-File (*.bdf). Then you can actually "see" what you have programmed. What array? How do you want to reduce the array size? Hmmm, if I ask my crystal-ball I think you want to create some instances of a Verilog-Thingy holding an array, and every instance should hold an array of different size. If this is the case try using "generics" in your code.Hello, I suggest this code:
module NodeType ( );
endmodule
module TreeTemplate ( );
parameter TREE_LEVEL= 4;
NodeType node();
generate
if ( TREE_LEVEL >0 )
begin
TreeTemplate# ( TREE_LEVEL-1 ) leftSubtree ( );
TreeTemplate# ( TREE_LEVEL-1 ) rightSubtree ( );
end
endgenerate
endmodule
I have used this principle in the implementation of sorting module. It was pleasant surprise, that one can make recursive modules in verilog.
