Timing violation with Altera GPIO in DDR mode
H,
I changed the I/O Standard to Differential 1.8V SSTL Class 1, but the negative slack is still there.
In the handbook Intel recommends to use PHYLite for source synchronous Interfaces with more than 200 Mbps.
I tried to set the parameters for this IP.
I set the Interface clock to 262.144MHz, clock rate of user logic: Full
If I do so, I cannot set the PLL reference clock to 262.144MHz. Just half of it, but I need to set this clock, because it is coming from the ADC.
I don't know why it is not possible. In the PHYLite User Guide
https://www.intel.com/content/www/us/en/programmable/documentation/bhc1410942178562.html#bhc1410941851660/en-us Table 3
the Max Core Clock Rate (Full) with Arria 10 Speed Grade -2 is 266MHz.
Do I miss something?
