MRenn
7 years agoTiming violation with Altera GPIO in DDR mode
I have a setup violation at the register after the input register. The input register is constrained as described in AN433. set_input_delay -add_delay -clock virt_adc_clk -min -0.6 [get...
MRenn
7 years agoI think I made a mistake with the settings of the PLL. I used -90° instead of 90° phase shift. With this and the assignments:
set_false_path -setup -fall_from [get_clocks virt_adc_clk] -rise_to \
[get_clocks iopll262|iopll_0|adc_clk]
set_false_path -setup -rise_from [get_clocks virt_adc_clk] -fall_to \
set_false_path -hold -rise_from [get_clocks virt_adc_clk] -rise_to \
set_false_path -hold -fall_from [get_clocks virt_adc_clk] -fall_to \
[get_clocks iopll262|iopll_0|adc_clk]I cuttet the wrong transfers.
Now with 90° pase shift I also get slacks at the input registers.
I could not find the maximum achievable frequency for the LVDS DDIO GPIO with an Arria 10 10AS066H3F34I2SG. Where can I find it?
Please find the test design in the attachment.
Thank you for your help!
