OlaG
3 years agoTiming-Driven Synthesis is skipped because it could not initialize the timing netlist
Using DCFIFO IP with standard settings causes timing-driven synthesis to be skipped and seems to create some timing issues in the design (optimizing of cells that should not me optimized). Warning me...
ShengN_altera
3 years agoHi,
It's recommended to check the option "Generate SDC files and disable embedded constraint". If not, keeping it unchecked will cause FIFO hardware failure for high frequency design.
Based on internal feedback, it's safe to ignore the warning as it wouldn't affect much on FIFO functional and timing.
Sheng
