Timing-Driven Synthesis is skipped because it could not initialize the timing netlist
Based on internal team, you may ignore the warning as it is not going to cause any functional issue and not affecting much.
Let me know if it causes IP timing not met or any performance degradation issue.
Sheng
- OlaG3 years ago
Dear Sheng,
Thank you for your quick feedback! I am a little surprised since this message seems to indicate that optimization could merge registers with incompatible timing, according to
"Timing-Driven Synthesis prevents registers with incompatible timing constraints from merging for any Optimization Technique setting." in https://www.intel.com/content/www/us/en/docs/programmable/683283/18-1/enabling-timing-driven-synthesis.html
What does the internal team recommend, to keep the option "Generate SDC files and disable embedded constraint" checked or not? Are there any detrimental effects of keeping it unchecked?
