skyjuice88
2 years agoTiming Constraints in DCFIFO through LPM
DCFIFO if generated through IP catalog will have the associated SDC constraints as well (set_max_delay/set_min_delay, set_net_delay and set_max_skew). What about DCFIFO instantiated through LPM (ht...
RichardT_altera
2 years agoYes, you are right. If you want the SDC to be generated, I would advise using the FIFO Intel FPGA IP to generate the SDC when click the 'Generate HDL.'
Richard Tan
