skyjuice88
2 years agoTiming Constraints in DCFIFO through LPM
DCFIFO if generated through IP catalog will have the associated SDC constraints as well (set_max_delay/set_min_delay, set_net_delay and set_max_skew). What about DCFIFO instantiated through LPM (ht...
skyjuice88
2 years agoHi Richard Tan,
The document that you pointed out refers to FIFO that is written through RTL inference. Can I confirm the same applies to LPM instantiation which is using the template provided by Quartus?
In Quartus --> Edit --> Edit Template --> Verilog HDL --> Intel Parameterizable Macros --> async_fifo
