skyjuice88
2 years agoTiming Constraints in DCFIFO through LPM
DCFIFO if generated through IP catalog will have the associated SDC constraints as well (set_max_delay/set_min_delay, set_net_delay and set_max_skew). What about DCFIFO instantiated through LPM (ht...
RichardT_altera
2 years agoHi,
There is no associated sdc generated through LPM.
If you choose to code your own dual clock FIFO, you must also create appropriate timing constraints in Synopsis Design Constraints format (.sdc).
Reference:
Richard Tan
