13 years ago
Timing Closure issue in Stratix V
I am compiling a basic NIOS system consisting of ITCM and DTCM ports. The target device is Stratix V. Its difficult to close timings with the NIOS sub system. Clock is 245.76 MHz.
The following optimization and synthesis settings are used.
set_global_assignment -name SMART_RECOMPILE ON
set_global_assignment -name OPTIMIZATION_TECHNIQUE SPEED
set_global_assignment -name PHYSICAL_SYNTHESIS_COMBO_LOGIC ON
set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_DUPLICATION ON
set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_RETIMING ON
set_global_assignment -name ROUTER_LCELL_INSERTION_AND_LOGIC_DUPLICATION ON
set_global_assignment -name ROUTER_TIMING_OPTIMIZATION_LEVEL MAXIMUM
set_global_assignment -name AUTO_PACKED_REGISTERS_STRATIXII NORMAL
set_global_assignment -name FITTER_EFFORT "STANDARD FIT"
The TNS is about -0.454 nsec.
Could anyone suggest some guidelines for timing closure. Please be reminded that the tight coupling impose a restriction of a fixed one cycle read latency on the instruction and data memories.
Thanks in advance,
1 Reply
    hi!! Have you tried to use the Quartus Design Space Explorer or changing the fitter seed!!
