DNguy4's avatar
DNguy4
7 years ago
Timing analysis on EMIF block
I am having a strange issue when doing timing analysis on my design. I am using the Intel external memory interface IP (emif) in my design and the timing analysis tool cannot recognize the user clock output of the emif block. Even the get_clocks command cannot find this user clock. Is there anything I need to do to the emif block to make the tool recognizing the user clock output? The tool can recognize all other clocks in my design except this one.
  • DNguy4's avatar
    DNguy4
    i found some conflicts in the sdc file that confuses the tool. it is fixed now.
    Thank you for your help.
  • BoonT_Intel's avatar
    BoonT_Intel
    Hi can you share the details of the conflict here? So that it can benefit other that facing the similar problem. Thanks in advance.​
  • DNguy4's avatar
    DNguy4
    BCT_Intel,
    when i generate the IP, the tool knows the frequency of the reference clock. If I create the reference clock clock in the top level sdc again, it get confused, even with the -add option. I remove the reference from the top level sdc and the tool is happy.
