13 years agoTimeQuest Issue on CDC Synchronization on Control and Data Path
Hi everybody,
I have an issue on appropriate TimeQuest Constrains on a Clock Cross Domain Design. My context is an external Synchronous bus with a control signal and a set of data signals: my design solution is synchronize the control signal (CS) through a 2 flip-flop metastability filter to produce a related signal (CS_synch) synchronized on the destination domain. And then use the variation on CS_synch(a falling edge in my case) to determine when to sample stable the external data signals (referred as Data[*] ) on the destination domain as Data_synch[*] . I don't think that set_false_path could be a comprehensive solution. The problem is that I suppose that my design works as long as the phase relation between CS and Data[*] is preserved through the routing from the pins to the synchronization destination registers in the FPGA. In other words my design can afford a Data[*] routing path greater than CS path of a specific amount that depends on the internal clock frequecy. Any suggestion? I tried with set_max_skew or set_max_delay , but I'm not sure that any of these is the right way to match delays between multiples routes. Thanks in Advance for any help! Claudia PS: here an extract of my sdc Solution 1 set_max_delay ---------------------------------- # EXT_BUS cycle time of core_clock, it is also the duration of each state of EXT_BUS EBI fsm (S0,S1 etc) set EXT_BUS_T_CYC_2_ns 6.7 # EXT_BUS CLKOUT high to chip-select CSn valid set EXT_BUS_T_CHCV_ns_MAX [expr $EXT_BUS_T_CYC_2_ns + 5] set EXT_BUS_T_CHCV_ns_MIN 0 # EXT_BUS CLKOUT high to data output (DATA[31:0]) valid (output in S2) set EXT_BUS_T_CHDOV_ns_MAX 9 # Max delay from EXT_BUS_CSn activation to data output (DATA[31:0]) valid # Taking as zero reference S0, the min delay for Csn activation and the max delay # for Data Output valid set T_CSlow2DOV_MAX [expr $EXT_BUS_T_CYC_ns + 9] set_max_delay -from [get_ports {DATA[*]}] -to [get_registers {*}] [expr $T_CLK_OSC_ns + $T_CLK_OSC_ns - $T_CSlow2DOV_MAX -$PCB_DELAY_MAX] Solution 2 set_max_skew only data path ---------------------------------- # Create a max skew constraint that includes only data path arrival # set_max_skew -from [get_ports { DATA[*] CS} ] 1 -include { from_clock to_clock clock_uncertainty } Solution 3 set_max_skew data path + clock path ---------------------------------- # Create a max skew constraint that includes only data path arrival # set_max_skew -from [get_ports { DATA[*] CS} ] 1 -include { from_clock to_clock clock_uncertainty }
