13 years agoThanks a lot Rysc,
from your response I suppose you suggest me that the best way is to use set_max/min_delay. In my case a transition high low of Cs means a start of a bus transaction, Data[*] are valid after CS goes low and with a max delay of 22,3 ns, and remain valid until the FPGA closes the transaction with an aknowledge signal. Data[*] doesn't go through a synchronized couple of flip-flop, but it's sampled when CS_synch goes low. FPGA internal clock has a 20 ns period . So I tried to constraint max_delay for Data[*] path, (being an extra delay on CS path not an issue, instead ... and otherwise I'm not able to relate delay between two paths !) with : set_max_delay -from [get_ports {M_DATA_A[*]}] -to [get_registers {*}] [expr $T_CLK_OSC_ns + $T_CLK_OSC_ns - $T_CSlow2DOV_MAX -$PCB_DELAY_MAX] # # 20 + 20 - 22.3 - PCB_delay_for_data_lines Could this be a correct way? Bye Claudia
