16 years agoTime Quest: Fail Setup Time n etc
Hi. I just switch from classic timing analysis(CTA) to time quest analysis(TQA).
Some steps are performed(as in TimeQuest Timing Analyzer.pdf) to do switching on timing analysis. After sdc file is generated, i din add any constraint into it as i totally have no idea what value to be added. FYI, When perform full compilation on CTA, everything is fine. However, in TQA, a lot of cases fail like Slow Model: setup, minimum pulse width and worst case timing Fast Model: minimum pulse width and worst case timing. FYI, In simulation, it still get the expected result. Wonder why though it fails. I try using the timing advisor and do as it instruct me. Anyhow, it does not solve the problem. Any idea on how to solve it? thanks
