16 years ago --- Quote Start --- Hi. I have no idea how to describe the details to you. However, i will attach the verilog and sdc file. Pls have a look on it. May you show or guide me on how to write sdc file? FYI, i just want to do timing simulation without any pin assignment. thanks a lot --- Quote End --- Hi, your create_clock command was not correct, therefore TimeQuest uses the default clock of 1GHz. I have a new SDC file attached. Kind regards GPK
