16 years ago
Time out problem
Hi, I am trying to make a counter which counts until timeout. Quartus II doesn't support using "wait for" or "after"? Then what can I do to end the process after a while?:confused:
    library IEEE;
    use IEEE.std_logic_1164.all;
    use IEEE.std_logic_unsigned.all;
    entity counter_test is
    port (
        CLOCK_50MHz: in std_logic;
        fin: out bit;
    end entity counter_test;
    architecture behav of counter_test is
        signal fin: bit := '0';
        begin
        process (CLOCK_50MHz)
    --        variable sub_cnt : integer := 0;
            constant timeout:time:=10 ms;
        begin
            if (CLOCK_50MHz'event and CLOCK_50MHz = '1')then
                cnt <= '1' after timeout;
    --            sub_cnt := sub_cnt + 1;
                end if;
    --    wait until (CLOCK_50MHz'event and CLOCK_50MHz = '1') for timeout;
        end process;
    end architecture behav;
    Where to begin...
    - You cannot synthesize this code - hopefully you know that.
    - You can't define "fin" as a port and a signal.
    - I guess the first question is are you trying to make synthesizable code? If so it is going to change the answer quite a bit.
    I am trying to make a synthesizable code. I made some mistakes in the previous code, now I changed it but it still doesn't work. I can compile it but the reault after simulation is not what I'm expecting. I am totally confused about how to impelement a time limitration here. I am using QuartusII, and that software doesn't support "wait for"......
    --- Quote Start ---
    --- Quote End ---
    I suggest you to have a look at quartus vhdl templates (there are counter examples I think) and a get a good book (or tutorials or good examples) about synthesizable VHDL code. http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=coding%20style
    "wait until" "after" are ignored by Quartus synthesizer.
    Have a nice day.
