16 years agoTime out problem
Hi, I am trying to make a counter which counts until timeout. Quartus II doesn't support using "wait for" or "after"? Then what can I do to end the process after a while?:confused:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity counter_test is
port (
CLOCK_50MHz: in std_logic;
fin: out bit;
end entity counter_test;
architecture behav of counter_test is
signal fin: bit := '0';
begin
process (CLOCK_50MHz)
-- variable sub_cnt : integer := 0;
constant timeout:time:=10 ms;
begin
if (CLOCK_50MHz'event and CLOCK_50MHz = '1')then
cnt <= '1' after timeout;
-- sub_cnt := sub_cnt + 1;
end if;
-- wait until (CLOCK_50MHz'event and CLOCK_50MHz = '1') for timeout;
end process;
end architecture behav; Where to begin... - You cannot synthesize this code - hopefully you know that. - You can't define "fin" as a port and a signal. - I guess the first question is are you trying to make synthesizable code? If so it is going to change the answer quite a bit.
