MEghb
6 years agoThe system only recognizes the FPGA for a couple of minutes!!!!
I installed the new Intel PAC on my workstation recently and I installed the software stack and opencl on my system to use the board. However, the systems only recognizes the board for a couple of mi...
MEghb
6 years agoHi,
Thanks for your response. You were right. I checked the temp as you suggested and it seems like the system is not cooling the FPGA well. I increased my fan speed in order the cool the FPGA, and it is working well after that. I checked the temperature regularly and it was not increasing like before. Do you think it could be harmful to the system since I need to keep the fans running at a higher speed than normal use?
Mostafa
