The Quartus Prime software quit unexpectedly.
Hi!
I'm using Quartus Prime Pro 23.4.
When I open signal tap, Quartus always quit unexpectedly.
I have to delete the .stp file to open signaltap every time, which is so suffering.
Below is the problem report.
How can I fix this? Really need your help, please!
Thank you~
Problem Details
Error:
Internal Error: Sub-system: CHI, File: /quartus/sld/chi/chi_control_nodes_scan.cpp, Line: 227
Must scan the device firstStack Trace: Quartus 0x2471a: CHI_CONTROL_NODES_SCAN::is_device_available + 0x2a (sld_chi) Quartus 0x110059: SEDQ_INSTANCE_WIDGET::qt_static_metacall + 0x539 (sld_sedq) Quartus 0x1fb3c0: QObject::event + 0x170 (Qt5Core) Quartus 0x36cf9: QWidget::event + 0xde9 (Qt5Widgets) Quartus 0xd56bf: QFrame::event + 0x2f (Qt5Widgets) Quartus 0x8960d: SEDQ_INSTANCE_WIDGET::event + 0x4d (sld_sedq) Quartus 0x1483f: QApplicationPrivate::notify_helper + 0x10f (Qt5Widgets) Quartus 0x138c2: QApplication::notify + 0x18b2 (Qt5Widgets) Quartus 0x1d4439: QCoreApplication::notifyInternal2 + 0xb9 (Qt5Core) Quartus 0x1d6194: QCoreApplicationPrivate::sendPostedEvents + 0x214 (Qt5Core) Quartus 0x5a76e: qt_plugin_query_metadata + 0x1f0e (qwindows) Quartus 0x21d573: QEventDispatcherWin32::processEvents + 0x73 (Qt5Core) Quartus 0x5a748: qt_plugin_query_metadata + 0x1ee8 (qwindows) Quartus 0x1d086b: QEventLoop::exec + 0x1bb (Qt5Core) Quartus 0x1d3403: QCoreApplication::exec + 0x153 (Qt5Core) Quartus 0x2c2e: qgq_main + 0x7e (quartus) Quartus 0x280a8: msg_main_thread + 0x18 (ccl_msg) Quartus 0x29282: msg_thread_wrapper + 0x82 (ccl_msg) Quartus 0x2b063: mem_thread_wrapper + 0x73 (ccl_mem) Quartus 0x25e6f: msg_exe_main + 0x17f (ccl_msg) Quartus 0x4466: WinMain + 0x156 (quartus) Quartus 0x3971: __scrt_common_main_seh + 0x105 (quartus) Quartus 0x17c23: BaseThreadInitThunk + 0x13 (KERNEL32) Quartus 0x6d720: RtlUserThreadStart + 0x20 (ntdll)End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0.18363
Quartus Prime Information
Address bits: 64
Version: 23.4.0
Build: 79
Edition: Pro Edition
- TingJiangT_Intel
Contributor
Have you changed the trigger condition in the signaltap?
Or the Quartus exits upon you open signaltap without any operation?
- PAIPAI
I haven't changed anything about signaltap.
Quartus just exits upon I open signaltap without any operation.
- TingJiangT_Intel
Contributor
I see, as this internal error is not exist in the database, could you please help upload the project for issue duplication?
BTW, you can download the standalone Programmer and Tools for using SignalTap only.
- PAIPAI
Sorry, I can't upload my project for some reasons.
But I'm sure this is not related to a specific project because I encounter the same problem when adding signaltap to Quartus's example design.
Is there any other solution? Thank you!
- PAIPAI
BTW, how to use signaltap in the programmer? I can't find any entry point or how to use it.
- TingJiangT_Intel
Contributor
You can try this link:
And you can install 'Intel® Quartus® Prime Pro Edition Programmer and Tools' under 'Add-On and Stand-Alone Software' which contains SignalTap and Programmer.
BTW, you can use other versions of Stand-Alione SignalTap different with the Quautus version you are using, which may not have this issue.
- TingJiangT_Intel
Contributor
