PAIPAI
2 years agoThe Quartus Prime software quit unexpectedly.
Hi! I'm using Quartus Prime Pro 23.4. When I open signal tap, Quartus always quit unexpectedly. I have to delete the .stp file to open signaltap every time, which is so suffering. Below is the pr...
TingJiangT_Intel
Contributor
2 years agoYou can try this link:
And you can install 'Intel® Quartus® Prime Pro Edition Programmer and Tools' under 'Add-On and Stand-Alone Software' which contains SignalTap and Programmer.
BTW, you can use other versions of Stand-Alione SignalTap different with the Quautus version you are using, which may not have this issue.
