15 years agoMy Comments next to your code
--Clock generation:
gen_clock : process(Clck)
begin
Clck <= not Clck after PERIOD1/2;
end process;
This does not need to be in a process. It works fine as a line outside.
--Row & Column generation for the system
gen_col_row : process
begin
nReset<='0';
wait for PERIOD1;
nReset<='1';
Columna<=(others=>'0'); --Initialize counters
Fila<=(others=>'0');
wait until ((Clck'event) AND (Clck='1')); --Clock synchronization
for i in 1 to 528 loop --Generates Fila(Row)
for j in 1 to 800 loop --Generates Columna(Column)
Columna<=Columna+'1';--Columna = column in spanish...
wait for PERIOD1;
end loop;
Columna<=(others=>'0'); --THIS DOESN'T WORK!!!!!!
Fila<=Fila+'1';--Fila=Row in spanish....
end loop;
end process;
You need to wait after Fila <= Fila + 1; otherwise it goes straight back into the next loop, and with no wait, the column <= '0' is overridden with the column <= column + 1; To fix this either: 1. after fila <= fila + 1; put wait for 0ns; (this causes the simulator to skip 1 delta cycle, and will set columna to 0; 2. Use variables instead of signals for row and column instead. They are updated immediatly and you wont have this problem.
