Tcl Error in Timing Analysis phase using LVDS SERDES RX IP
Upon checking, this is caused by the typo in Arria10_DAQ.v (Line 298)
After replacing line 298 with .adc3_clk(ADC3_CLK), you will see Fitter error below:
Error(14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 IOPLL(s)). Fix the errors described in the submessages, and then rerun the Fitter. The Intel FPGA Knowledge Database may also contain articles with information on how to resolve this periphery placement failure. Review the errors and then visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error(175001): The Fitter cannot place 1 IOPLL, which is within LVDS SERDES Intel FPGA IP adc_lvds_rx_altera_lvds_1940_p47vjlq.
Info(14596): Information about the failing component(s):
Info(175028): The IOPLL name(s): global_adc_handler|adc_lvds_rx3|lvds_0|core|arch_inst|internal_pll.pll_inst|altera_lvds_core20_iopll
Error(16234): No legal location could be found out of 16 considered location(s). Reasons why each location could not be used are summarized below:
Error(175006): There is no routing connectivity between source pin and the IOPLL
Info(175026): Source: pin ADC3_CLK
Info(175015): The I/O pad ADC3_CLK is constrained to the location PIN_AL5 due to: User Location Constraints (PIN_AL5)
Info(14709): The constrained I/O pad is contained within this pin
Info(175021): The pin was placed in location pin containing PIN_AL5
Error(175022): The IOPLL could not be placed in any location to satisfy its connectivity requirements
Info(175029): 14 locations affected
Info(175029): IOPLL_2A
Info(175029): IOPLL_2F
Info(175029): IOPLL_2G
Info(175029): IOPLL_2H
Info(175029): IOPLL_2I
Info(175029): IOPLL_2J
Info(175029): IOPLL_2K
Info(175029): IOPLL_2L
Info(175029): IOPLL_3C
Info(175029): IOPLL_3D
Info(175029): IOPLL_3E
Info(175029): IOPLL_3F
Info(175029): and 2 more locations not displayed
Error(20196): Location(s) already occupied and the components cannot be merged. (2 locations affected)
Info(175029): IOPLL_3A. Already placed at this location: IOPLL global_adc_handler|adc_lvds_rx1|lvds_0|core|arch_inst|internal_pll.pll_inst|altera_lvds_core20_iopll
Info(175029): IOPLL_3B. Already placed at this location: IOPLL global_adc_handler|adc_lvds_rx2|lvds_0|core|arch_inst|internal_pll.pll_inst|altera_lvds_core20_iopll
This error indicates that there is another design component already placed at this location and the two components are not mergeable. Refer to details in Info(175029)
To fix this fitter error, reassign ADC3_CLK to other pin location. After reassigning the pin location, the compilation passed without the error
Error(23035): Tcl error: ERROR: Argument <node_object> is an object filter that matches no objects. Specify one matches only one object.
KhaiY
