ldm_as
6 years agoTCL commands for adding/removing signals to/from SignalTap
Hi All, What commands should be used for adding/removing the signals to/from SignalTap? Thank you!
ldm_as
6 years agoIs it possible to re-arrange the SignalTap instances?
RichardT_altera
6 years agoDo you mean to run a specific instance? If so, yes.
run -instance <instance> -signal_set signal_set_1 -trigger trigger_1 -data_log log_1 -timeout 5
Just specify the <instance> that you want to run in your tcl command.
