ldm_as
6 years agoTCL commands for adding/removing signals to/from SignalTap
Hi All, What commands should be used for adding/removing the signals to/from SignalTap? Thank you!
ldm_as
6 years agoThe 'quartus_sh --qhelp' is an invalid command
RichardT_altera
6 years agoYou need to run quartus_sh --qhelp from the command prompt.
In the command prompt, go to where the quartus_sh.exe file directory located e.g. C:\intelFPGA\19.1\quartus\bin64.
Then, run quartus_sh --qhelp and GUI window will pop up showing the detailed listing of all command-line executables and Tcl commands including usage examples.
