ldm_as
6 years agoTCL commands for adding/removing signals to/from SignalTap
Hi All, What commands should be used for adding/removing the signals to/from SignalTap? Thank you!
RichardT_altera
6 years agoYou can check all available signal tap tcl scripting by opens the Intel Quartus Prime Command-Line and Tcl API help
browser by insert command: quartus_sh --qhelp
If not found, it most likely not available. You might need to manually add/remove the signals tapped in the .stp file directly.
