8 years ago
SystemVerilog logic type as bidir
I'm new to SystemVerilog and have a question about a warning Quartus is throwing. I'm working with a design done by someone else.
In my code I have a 2 interfaces which have port type logic. In the module there is assignment of one logic type to another... for example
interface typeA();
logic[3:0][3:0] mem_A;
endinterface
interface typeB();
logic[3:0] b1;
logic[3:0] b2;
logic[3:0] b3;
endinterface
module dut(typeA in, typeB out);
assign out.b1[0] = in.mem_A[0];
assign out.b2[1] = in.mem_A[1];
assign out.b3[2] = in.mem_A[2];
endmodule
I'm trying to get rid of this warning but don't know what do to since the interfaces are being used multiple times all over the design.
Warning (10665): Bidirectional port "IN.pix[0][2]" at If.sv(47) has a one-way connection to bidirectional port "OUT.grn[0][2]"
Thanks in advance.
    The error message has the identifiers 'pix' and 'grn', but they do not exist in the source code.
    --- Quote Start ---
    --- Quote End ---
    The code is just an example...the warning is copied from Quartus. In all correctness the warning to match example should have been
    Warning (10665): Bidirectional port "in.mem_A[0][0]" at If.sv(#) has a one-way connection to bidirectional port "out.b1[0][0]"
    Warning (10665): Bidirectional port "in.mem_A[0][1]" at If.sv(#) has a one-way connection to bidirectional port "out.b1[0][1]"
    Warning (10665): Bidirectional port "in.mem_A[0][2]" at If.sv(#) has a one-way connection to bidirectional port "out.b1[0][2]"
    --- Quote Start ---
    interface typeA();
    endinterface
    interface typeB();
    logic[3:0] b1;
    logic[3:0] b2;
    logic[3:0] b3;
    endinterface
    endmodule.
    --- Quote End ---
    Don`t you think that, here you are trying to access one interface members by another interface since an interface is a bundle of nets or variables & interface construct in system verilog was specifically created to encapsulate the communication between blocks or modules.
    Refer the attached pdf. for detail about an interface.
    Best Regards
    Vikas Jathar
