System Console master_read_memory fails above 7688 bytes on Agilex 5 (AXE5-Eagle)
Hi covfefe,
Just an quick update to let you know that we have received your support ticket and are currently investigating the issue.
We will update you as soon as possible.
Thank you.
ZiYingE_Altera
- covfefe1 month ago
thank you for looking into it. were you able to replicate the issue?
HiZiYingE_Altera Just checking in to see if I should expect any update on this item?
- ZiYingE_Altera1 month ago
Contributor
Hi covfefe,
Sorry for the delayed response.
Would it be possible for you to provide the complete project in a .qar file and attach it as a .zip file?
We would like to investigate the issue using a similar device available in our lab.
This may require us to modify the target device and rebuild the design, so having the complete project would be very helpful for our analysis.
Thank you.
ZiYingE_Altera
