15 years ago
Synthesizing LPM_DIVIDE with positive SKIP_BITS parameter
Hey guys,
I am relatively new to VHDL and would be grateful to get some help.
I was trying to instantiate the lpm_divide megafunction using the following code:
ENTITY dummy IS
PORT
denom : IN STD_LOGIC_VECTOR (2 DOWNTO 0);
numer : IN STD_LOGIC_VECTOR (6 DOWNTO 0);
quotient : OUT STD_LOGIC_VECTOR (6 DOWNTO 0);
remain : OUT STD_LOGIC_VECTOR (2 DOWNTO 0)
END dummy;
ARCHITECTURE SYN OF dummy IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (6 DOWNTO 0);
SIGNAL sub_wire1 : STD_LOGIC_VECTOR (2 DOWNTO 0);
COMPONENT lpm_divide
GENERIC (
lpm_drepresentation : STRING;
lpm_hint : STRING;
lpm_nrepresentation : STRING;
lpm_type : STRING;
lpm_widthd : NATURAL;
lpm_widthn : NATURAL;
SKIP_BITS : NATURAL
PORT (
remain : OUT STD_LOGIC_VECTOR (2 DOWNTO 0);
END COMPONENT;
BEGIN
quotient <= sub_wire0(6 DOWNTO 0);
remain <= sub_wire1(2 DOWNTO 0);
lpm_divide_component : lpm_divide
GENERIC MAP (
lpm_drepresentation => "UNSIGNED",
lpm_hint => "MAXIMIZE_SPEED=6,LPM_REMAINDERPOSITIVE=TRUE",
lpm_nrepresentation => "UNSIGNED",
lpm_type => "LPM_DIVIDE",
lpm_widthd => 3,
lpm_widthn => 7,
SKIP_BITS => 2
PORT MAP (
denom => denom,
numer => numer,
quotient => sub_wire0,
remain => sub_wire1
END SYN;
I am trying to divide a 7 bit positive number by a 3 bit one, apriori knowing that the 2 MSBs of the quotient are zeros. This fact can be exploited in synthesis optimization by setting the "SKIP_BITS" parameter to the value 2.
When I attempt to synthesize this entity, I receive the following error message (in Quartus II 9.1):
"Error: MGL_INTERNAL_ERROR: The source port lpm_divide|sign_div_unsign inst divider|alt_u_div inst divider|prestg already has one or more bits in the range 1 to 0 assigned. CAUSE : The port range was already assigned a value. The new value can not be reassigned."
Could you guys help me work this out ??
Thanks ahead.
    so far no problem. You don't need to the two statements at top.
    quotient and remainder are outputs of lpm and should only be driven by it.
    just read these out.
    Thanks a lot for the tip kaz. I've updated the code:
    ENTITY dummy IS
    PORT
    END dummy;
    GENERIC (
    lpm_hint : STRING;
    lpm_type : STRING;
    SKIP_BITS : NATURAL
    PORT (
    END COMPONENT;
    BEGIN
    GENERIC MAP (
    lpm_widthd => 3,
    lpm_widthn => 7,
    SKIP_BITS => 2
    PORT MAP (
    denom => denom,
    numer => numer,
    quotient => quotient,
    remain => remain
    END SYN;
    I am afraid you missed the point of my question:
    I am receiving the earlier quoted error message when the value of the SKIP_BITS generic is set to be higher then 1. I can not figure out the reason for the error.
    I'd be very grateful if you could give me a tip on that too...
    sorry for my earlier post. Your code was ok with connections but the names misled me.
    Anyway, it seems that skip_bits in your case should be set to 1 maximum and then quartus accepts it. My experience with lpm divider is fresh and I think they mean that 7 bits(0~127)/3 bits(0~7) can have quotients from 127(127/1) ~ 18(127/7). If we ignore 1 then max quotient is 127/2 and needs 6 bits hence 1 bit can be skipped. but sounds silly if only one bit is allowed skip as div/2 means one bit less always.
