RBash
6 years agoSynthesizing design for PAC with Arria 10 GX fails
I'm trying to synthesize a design for a PAC with Arria 10 GX, but get the following messages when the synthesis script finishes. Since the error message doesn't give any particular information, I don...
- 6 years ago
Thanks for the report file. It looks like there is a conflict on the your Quartus design where the IP name use is the same.
Below is the error message when Quartus Synthesis is performed. You will need to make some changes on your design so that it is not using the same file name.
Error (19021): The same file name "mm_bridge_0" is used for different IP files. The same name cannot be used for more than one IP file.
JohnT_Altera
6 years agoHi,
Could you provide your system variable before you compile your design? I would like to make sure that the environment is correct.
- RBash6 years ago
The following is the output of printenv. I removed other environment variables that are not related to Intel FPGA, if you're looking for a specific variable please let me know.
QSYS_ROOTDIR=/winhomes/rb274/intelFPGA_pro/18.0/qsys/bin INTELFPGAOCLSDKROOT=/opt/fpga/inteldevstack/intelFPGA_pro/hld QUARTUS_HOME=/opt/fpga/inteldevstack/intelFPGA_pro/quartus OPAE_PLATFORM_ROOT=/opt/fpga/inteldevstack/a10_gx_pac_ias_1_2_pv FPGA_BBB_CCI_SRC=/winhomes/rb274/intel-fpga-bbb-master AOCL_BOARD_PACKAGE_ROOT=/opt/fpga/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/opencl_bsp
